hans030390
My westinghouse (19" widescreen, 16x10) zooms in on a 16x9 image...it fills up the screen, so the top and bottom section of the image are fine, but it cuts off the left and right side.
It's worse on 720p than on 1080i.
The scaling option (full, zoom, normal) does nothing for me...it's stuck at full.
So now I'm stuck with a cut off 16x9 image, BUT that's only with a high-def signal. For example, I can run FFXII in widescreen and it will let me scale it to fit the screen properly. But anything in a HD signal gets stuck at full and cuts off the sides of the image.
Is there ANY sort of workaround for this?
