Any way to be logged onto AIM with 2 SN's at the same time?
The Dancing Peacock
3,385
Will Trillian allow you to log in twice? Or one with Trillian and one with AIM? I haven't attempted to try 2 versions of aim at once yet. I'm at work and not on a windows machine to try it out. IRIX is cool, but has it's drawbacks.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Use AIM for one, then go HERE (and click START) for the second.
:D
The Dancing Peacock
3,385
is AIM+ that thing they want you to pay for? Definitely not gonna pay to do this :)
My guess is that Trillian and Aim will probably be the best bet. I don't like the quick buddy thing, which I wanted to try and stay away from. I use the old version via IRIX and Linux browsing here at work. I know that will definitely work, I've done it before.
I wont be able to try it out till after 1 a.m. I'm currently at work, bored, thinking about random stuff :)
bandXtrb
Banned
May 27, 2001
2,169
I can logon to as many AIM screennames as I want to by a process where I "clone" the AIM client. It requires hex editing the aim.EXE file, though. I have ten aim clients set up in folders AIM1, AIM2, AIM3, etc. I may be able to send the already hexed EXE's to you if you want to go this route (you need AIM 4.7)
The number of AIM clients you can have running is limited by your systems ability (resources, memory, etc) and perhaps a cap on the number of AIM connections that AIM will allow you to have from your internet address.
Supermercado
5,893
Anyone know if it's possible to sign on to two different names if you use different users under WinXP? I have my user that's the primary one on the computer, but my brother wants to leave his signed on. If I create a user for him and he logs on, can we both run AIM at the same time from the same computer?
Yeeny
10,848
Yes, I do it all the time, with my kids screen names and my own.
Supermercado
5,893
I thought so. Thanks.
The Dancing Peacock
3,385
Originally posted by: JonathanM
with trillian it is possible to have more than one aim account signed on.
Is it the newest version, or an older one? I've never used trillian before, never had seen the need until now. I wanted to try and keep resources uses down, that's why I wanted to find 1 client that could do it.
Yoda, what is AIM+?
b0mbrman
29,470
Yoda, what is AIM+?
Overview
Download
SHoddyCOmp
2,072
Yet ANOTHER vote for AIM +. It has a cloning feature. I had like 8 AIMs going at once one time for a minute or 2 :D No, you dont pay for it. It also has a nifty AIM+ History you can activate so those people who go back on what they say earlier you can copy what happened from months ago as long as you dont clear it :) I dont use it on this computer though so its relatively safe to IM me. Mine crapped out after i sort of helped the HD die and I'm currently on an even slower one. :(
zeruty
2,276
trillian can do it easily
I usually have two accounts logged in, in one instance of trillian
I've had up to 5 before
only disadantage is it merges all of the buddylists together, which is actually how I prefer it... so it's an advantage to me
Braves
Banned
Dec 16, 2001
884
AIM+ is great, although I think there are a couple bugs with it... mostly in the editing profile section and various progz that i've used which get confused by AIM+'s coding or something. But yeah, AIM+ will do the trick for you, it's fast, easy, just like AIM, and now that I'm having personal problems I like to use the built in chat logger and reread the happy conversations i've had in the past :)
The Dancing Peacock
3,385
trillian seems cool for now. Took me a little while to get multiple AIM sn's set up, just cuz it wasn't intuitive at first. Makes sense now. :)
dakata24
6,366
i like trillian cuz of the skins.. only thing is that it doesnt save profiles in 0.725.
xirtam
4,693
Oh, my bad. I looked at your second question and it asked "Or one with Trillian and one with AIM" and was going to reply "yes." I haven't tried multiple logs with Trillian.
