any USB keyboard with USB hub and 10ft cord?
I have a Dell USB Keyboard .. it came with the dell 8200 .... however there are many good choices out there .. best bet is go to Staples
or Compusa ... see what they have, if you like it's style, layout, key feel, size, features, etc .. then if you like the price .. if not check
on line for the best deal once you know which one you want
tnx
I already went to Staples - they don't have any with USB hub built in.
I'll try Fry's to see what they have.
went to fry's - nothing there with USB hub except kb for Mac - I don't need it
any recommendation which one and where I can get kb with built in USB hub?
thanks
Originally posted by: mikek753
Originally posted by: Tu13erhead
Why not just buy a hub separately?
the point is to run just ONE wire via usb extender 8ft and then connect mouse or / and gamepad to keyboard.
Okay, so buy an extension, plug the USB hub into that, and then plug the keyboard into the USB hub.
Check Ebay. A few HP PC's came with a very decent keyboard with the 2 port USB hub built in and media buttons across the top. Mine even has a rotary volume control which I love.
Originally posted by: Unkno
the logitech G15 has a built in hub...
one or two USB devices G15 can take?
I checked logitech site, but can't find any info about it :-(
can I connect G5 into G15? will it work at full speed for G5?
thanks
