I sold my Mustang after we had the baby so that we could afford to let me wife keep her newer car (Chevy Equinox) but I still needed a cheap car to drive to work. Just so happens my grandpa was selilng his 96 Mercury Mystique which I bought for a measly $750. It's really not a bad car and gets 30mpg so I'm happy. The car actually looks pretty decent too except for the trunk lid... he backed into something and it busted it up pretty bad. I picked up a replacement trunk at the junkyard last week for only $25 -- in perfect condition except it's plum purple and my car is a champagne color.
I was going to have it professionally painted but everyone wants $400+ to do it. Considering this is a $750 beater I thought about just painting it myself... with color matched spray paint. Basically the touch up paint but in a 12oz aerosol spray can. I want to keep this project as cheap as possible so no buying a spray gun, air compressor, etc... I know it's not going to be perfect and I've painted rims and sportbike body panels before with quality spray paint and they've came out decent if you're standing 5ft away. I'm just not sure how to prep the trunk lid.
I was thinking something like 100 grit sandpaper to knock the plum paint off then spray a few coats of primer and then maybe 400-600 grit to smooth that down. Then multiple light coats of the color. Is that correct? If so do I need to go on with an really fine sandpaper over the color like 1200 grit? Thought about spraying on a couple of coats of clear coat but not sure if that will look better or worse. Spray paint clear coat usually looks yellow when I've tried it before unless I was just going to do 2-3 very light coats to protect it some.
