Originally posted by: CptObvious
Originally posted by: Fritzo
Wuss. I did a 36" TV up the stairs by myself. Of course I'm 6'4", so I have long arms (I wouldn't recommend this- thought I popped a nut when I was done).
32" shouldn't be that bad to lift.
The Wega weighs >150 lbs.
Aw come on, you can handle that yourself! I weight about 120lbs and I can lift at least that much. Not for long distances, mind you, but I
can do it. Working in a warehouse for even just a few months can build up some muscle. My 70lb monitor felt a lot lighter by the end of the summer.
Have you got neighbors? Even if you don't know them, maybe just ask one of them to give you a hand, and offer a coke/beer/$5-10 or something. Just kindly make sure they know that if they drop it, they pay for it.
The other option, which I might use, would be to tape a piece of cardboard to the top, put the TV upside-down at the top of the stairs, and slide it down. Walk in front of it as you ease it down.
I suggest it being upside down, because the bottom likely has support feet or other odd shapes which could impede easy movement down stairs. The top is probably flat. The cardboard is there to prevent scuffing.
In any event, there's always a way of moving heavy things yourself if you get creative. I was able to lift a large chest freezer up onto a custom-made dolly by myself. It took a 4ft 2x4, and several smaller 2x4's. Lift it up a bit with the long board as a lever, slide small piece underneath. Go to other side, and repeat. Continue until it's high enough to fit the dolly underneath.
I've also managed to move a pellet furnace weighing 290lbs. Mechanical advantage. If it doesn't exist, do something that provides it.
