I work with a company where almost everyone works from home on their PCs or laptops. There are no hardware standards other than being able to run XP, nor can I realistically impose software restrictions since some of these units are family computers. The company is rapidly growing and I am looking for an effective approach to ensuring some baseline of security.
Right now, my loose protocol is as follows:
* PC must run XP with SP2 and all updates
* Broadband users must be behind a router
* Auto updates and Windows Firewall both on (I disable the latter only if a better product is installed)
* Antivirus software must be current (any vendor)
What, if anything, should I add to the list? How often should I audit these machines? By audit, I mean connect via VNC and give a quick checkup for both security and ensure that the critical business apps (Groove, Outlook, etc.) are functioning.
