Any tests on tri-fire 79xx with frame pacing drivers.
biostud
20,106
7,211
I haven't been able to find any tests of tri-fire of the 79xx cards after the frame pacing drivers from AMD has been released. Has anyone else seen some results?
BrightCandle
4,762
Frame pacing as far as I know still doesn't support triple cards. AMD hasn't said anything on the issue which likely means it hasn't been fixed. They haven't mentioned DX9 in a while either and that still isn't fixed either.
Leadbox
744
63
It works with 3 cards. I dont know if it works in eyefinity yet.
Eyefinity should now work, but not 1 reviewer has bothered to test it.
According to Ryan Smith, AMD are using the PCI-E bus and Xfire bridge with the 7000 series cards too.It would be fascinating to see how they did that
Mr Shrout over at PcPer said he was going to test it the week after the driver came out, it's been 3 weeks since and nothing going.
3DVagabond
11,951
204
Probably means that it works. PCPer loves to write an AMD expose'.
el etro
1,584
14
Frame Pacing on Eyefinty and 4k works in all GCN 2-way crossfired cards now with 14.1 beta. Don't know if 3 or 4 card setups can't have the feature enabled.
