any side effects of using a wide-angle convertor?
SexyK
1,343
4
I'm fairly certain you lose light either way, and therefore lose aperture. But someone please feel free to correct me if I'm wrong here.
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Jan 2, 2006
10,455
35
yeah, you don't lose any light with wide angle adapters, but like people said, you will definitely lose quality.
996GT2
5,212
A wide angle converter will reduce image quality considerably and also may add distortion and other imperfections on top of what your lens already has. If you're using an expensive lens, then putting a wide angle converter on top of that will give it image quality worse than the kit lens that comes with many cameras.
Teleconverters, on the other hand, are often designed to be used specifically with a few lenses, and feature high quality optics that only reduce image quality a bit (and are quite expensive as a result). However, there is still a drop in quality.
For example, here are some resolution numbers for a very expensive Canon 300mm f/4L IS, as tested on a Rebel XT:
Without 1.4x Teleconverter, f/5.6
Center: 1996.5 lines of resolution
Border: 1928.5 lines of resolution
With Canon 1.4x Teleconverter, f/5.6
Center: 1796.5 lines of resolution
Border 1596.5 lines of resolution
