Any recommendations for shop vacs?
JohnCU
Banned
Dec 9, 2000
16,528
4
Tired of paying $3-$4 bucks to go vacuum my car, looking for something with a lot of power, but never bought one before so...recommendations ?
Rike
2,614
I have a Craftsman 2.5 gallon shop vac that I've been quiet happy with. It's been running strong for going on 9 years.
Edit: And yes it really sucks, but it a good way! ;)
BoomerD
66,279
14,699
Shop vacs are like girlfriends...
They all suck...some are just better at it...
33,918
I've had really good luck w/ a Craftsman Supersux 10,000 or whatever it's called. Vacuuming up cat hair, nails, broken glass, dirt, dust, more cat hair, rocks, even more cat hair, etc. works great. One thing about vacuuming cars is that the vacuum builds up static really fast so that I get continuously shocked the whole time I use it on the car. Some folks might enjoy it.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
I recommend that you get the hose with the larger diameter. I had the same shop vac as a friend, except I had the (1 1/2 inch?) hose, he had the 3 inch hose. His was 10 times better than mine - I couldn't figure out why until I replaced my hose.
arcas
2,155
1) Ignore the HP ratings. They're all 110V which means you won't be able to draw more than, say, 12- or 15 amps.
2) Don't be tempted to buy a big 12- or 16-gallon one unless you really think about it hard. Remember: you have to store it somewhere when you're finished.
3) Sears used to sell a wet-dry vac that had an optional carpet cleaner attachment (think a poor-man's Rug Doctor).
4) Hose size matters
5) Most air filters are washable (use a garden hose). But buy an extra filter or two when you buy the vac just in case they stop making the filters later on...
Vette73
21,503
9
I needed one for my shop and cars. I found that sears had the best price when they were on sale. So wait for a sale/coupon beofre you buy.
Also as arcas pointed out don;t go for the biggest one. Get one that will be the right size for you. I got a 16gallon higher HP rated one as i use it for my wood shop so it is being used as my poor mans dust collection system right now.
Vette73
21,503
9
Originally posted by: HiTek21
I've been looking for a portable shop vac to help me detail cars, does anyone have this one?
Text
I don;t have that one. But from teh specs it looks liek it would do the job very well.
Best bet buy one and try it on your car. If it works, keep it. If not return it the next day.
