I recall hearing that there you can't put pc133 in a pc66 slot as it can't clock lower than pc100 for some strange reason or something to that effect. Is there any reason whatsoever why I'd have to use pc66 exclusively? TIA.
You could have the old high-density problem where your stick will only be half it's size. The older chipset may not properly recognize newer high-density PC133 modules.
