- Apr 6, 2001
- 560
- 0
- 0
A uniform solid disk with mass m and radius R is pivoted about a horizontal axis through its center, and a small object of the same mass m is attached to the rim of the disk. If the disk is released from rest with the small object at the end of a horizontal radius, find the angular velocity when the small object is at the bottom. (Use g, m and R as necessary.)
any help will be appreciated. thanks.
