BarnyardMonkey
Hopefully someone can give me an answer on my monitor that went bad.
it worked fine for quite awhile,then every now and then i would hear a light pop noise and the monitor screen would sorta flash.
then everything would be fine after that.
so,a few days later i turned it on and got nothing.
just the power light.
Its a "Gateway 19" EV900".
i hear they have alot of problems.
I searched around and came across a page that listed a few Resistors that may have went bad.
so i checked them out but for some reason there is 2 Resistors that won't read the right voltages when soldered in the board.
R573 should read 68K,but it reads 15K.
but after taking it out of the board it reads the right voltage which is 68K.
And there is also one other that does the exact same thing.
but its one of the turn knobs closest to the FBT.
should be 20K,but reads 10K in the board,and 20K out of the board.
Was hoping maybe someone that knows a bit about Repairing monitors could tell me what may be the prob with the false readings before i toss out the monitor.
Shawn.
Shawn.
