Any manufacturers make cables in small and incremental lengths?
eflat
my goal is to have all the cables in my case just the right length.
belkin and the ones i am looking at it seems like the shortest ones are usually over a foot long.
i need ones like 5 inches and less for an sata cable, for example..
am i going to have to make my own to achieve this?
mycableshop.com 6", red. Googled "short SATA cables." Time 1min. 😉
There are a couple of intresting threads on sleeving that are current, all posted
in the last two weeks on this forum.
Galvanized
Galvanized
You Googled it? THen how the hell do I know if it is sh!t or not. If I wanted a piece of sh!t I would have googled it not asekd here 😉
IDK, buy one and do a review for us.
I might want to buy some down the line 😛
Galvanized
lolol funny GY :laugh: hmmm...a sh!t sata cable? they all look like cr_p to me anyways...I say go for it citizen...get the 6"
I think that SATA cables are a specific length for a reason. Maybe the same reason that an ATA133 HDD won't work with a 10" cable. Maybe has something to do with attenuation at higher transmit speeds.
VANTEC makes ROUND 10" Floppy cables and 18"&24" Round IDE , 1 & 2 device cables. I don't know if custom lengths are available.
Lemme give you a piece of advice.
Shhhh, very secret.
The "interconnect" cables sold for hundreds at pro audio shops...
... and...
The "gold RCA" cables sold for $10 at Radio Shack...
... won't sound any different.
Shhh, don't tell anyone.
Originally posted by: NotquiteanooB
I think that SATA cables are a specific length for a reason. Maybe the same reason that an ATA133 HDD won't work with a 10" cable. Maybe has something to do with attenuation at higher transmit speeds...
Don't know about SATA cables but I've read that ATA100 cables "should" be a minimum length and have a specific ratio of lenth between connectors. However, manufacturers sometimes do not follow these recommendations. Does it matter? Dunno. I do know that "odd length" cables often work just fine.
