Any legitimate and inexpensive way to get a Win7HP-Pro anytime upgrade key?
XMan
49
Bought a 32GB RAM kit like a moron and forgot HP only supports up to 16GB. I have one program I need that isn't compatible with 10. I checked the usual places but they're either ridiculously expensive or not available. MS no longer sells them via the OS, either.
Mushkins
1,631
An upgrade key? No. You can get a full retail copy of Windows 7 Pro though and do a clean reinstall.
Or you could upgrade to 10 and run that one lone app in a Win7 VM. Windows 10 has a watered down version of HyperV built right into it. Wouldn't cost you a dime and would hold you over until you can shed yourself of that app (or they update it).
XMan
49
I'm going to try the 10 option to start with, looks like I can get a Pro OEM for ~50 bucks if necessary.
Thanks for the info!
Edit - Grr, 10 Home doesn't have HyperV.
XMan
49
Got a Windows 7 Pro license. :D 32GB RAM support, and I can run PowerProducer in an XP virtual machine and actually update Radeon drivers! 8)
