Originally posted by: alkemyst
check into newsprint archiving.
You want to do alot more than just press it between glass usually. Newsprint is hard because it's not meant to last and some is even designed to biodegrade quickly.
Usually neutralizing acids, isolating the media from air and humidity, and then protecting from UV is important for printed goods....the ink used is also a limiting factor....the best inks are designed for archival use and very expensive compared to run of the mill inks.
