Hey guys, I want to add another fan to my case for better cooling. I have a slot free for a 120mm fan at the front. I have an Antec SLK3700AMB case. Any suggestions for a good thermally-controlled 120mm are welcome
I think I've decided to go with the Papst. It's pricey, but I feel it's worth it since I only need one. I hook my fans to a baybus, so I don't worry if the temps the fan decides to spin up at are in line with the rest of my system.
I've got an Acoustifan 120mm... It has a thermal sensor, can be controlled manually... It's VERY quiet. Keep in mind they are only designed to run for about 3 years 24/7, so they don't have the longevity of some other fans. You can get them for around $25.
