Any "home networking for dummies" tutorials?
KDOG
14
Ok I have my main/office computer running my wireless router (Netgear WNR2000 - its' an N router) and I put a wireless network card in the stepsons' computer downstairs and have the file/print sharing on and that seems to be working fine. Now I just bought a Dell laptop and while I can surf the net just fine I can't access file/print stuff. I also would love to put a password on the router to keep other people from hopping on. As you guessed, I have no idea how to do this. Is there a tutorial for idiots like me? I'll read the sticky of course. But any help would be appreciated.
JackMDS
29,563
432
File and Printer Sharing.
Make sure that the Software Firewall on each computer allows free local traffic. If you use 3rd party Firewall On, Vista/XP Native Firewall should be Off, and the active Firewall has to adjusted to your Network IP numbers on what is some time called the Trusted Zone (consult your 3rd Party Firewall instructions.
General example, http://www.ezlan.net/faq#trusted
Vista File and Printer Sharing - http://technet.microsoft.com/e...rary/bb727037.aspx
Windows XP File Sharing - <http://support.microsoft.com/d...id=kb;en-us;304040
Printer Sharing XP - <http://www.microsoft.com/windo...neycutt_july2.mspx
Windows Native Firewall setting for Sharing XP - <http://support.microsoft.com/kb/875357
Windows XP patch for Sharing with Vista - <http://support.microsoft.com/kb/922120
Wireless Security.
From the weakest to the strongest, Wireless security capacity is.
No Security
Switching Off SSID (same has No Security. SSID can be easily sniffed even if it is Off)
MAC Filtering______(Band Aid if nothing else is available, MAC number can be easily Spoofed).
WEP64____(Easy, to "Break" by knowledgeable people).
WEP128___(A little Harder, but "Hackable" too).
The three above are Not considered safe.
Safe Starts here at WPA.
WPA-PSK__(Very Very Hard to Break).
WPA-AES__(Not functionally Breakable)
WPA2____ (Not functionally Breakable).
Note 1: WPA-AES the the current entry level rendition of WPA2.
Note 2: If you use WinXP bellow SP3 and did not updated it, you would have to download the WPA2 patch from Microsoft. <http://support.microsoft.com/kb/893357
The documentation of your Wireless devices (Wireless Router, and Wireless Computer's Card) should state the type of security that is available with your Wireless hardware.
All devices MUST be set to the same security level using the same pass phrase.
Therefore the security must be set according what ever is the best possible of one of the Wireless devices.
I.e. even if most of your system might be capable to be configured to the max. with WPA2, but one device is only capable to be configured to max . of WEP, to whole system must be configured to WEP.
If you need more good security and one device (like a Wireless card that can do WEP only) is holding better security for the whole Network, replace the device with a better one.
Setting Wireless Security - http://www.ezlan.net/Wireless_Security.html
The Core differences between WEP, WPA, and WPA2 - http://www.ezlan.net/wpa_wep.html
KDOG
14
wow, alot of info there. I'm totally confused now. LOL. I need a step by step guide to turn my network into a private one, but still allow complete access between all the computers in the house...
