Originally posted by: PUN
if I buy wrt54gl, will it work right out of the box in terms of networking the computers on both side of the router? does bridging client to the main router involve some knowledge of networking exp?
If you want a simpler solution, you can try an off-the-shelf client mode bridge. These are not very common, and typically more expensive, but in theory should be simpler, and come with vendor warranty and support. That said, the last person I gave this advice to failed to get such a device, a SMCWEB-N, working in his network. D-Link has a similar device -- the DAP-1522. Linksys has had such devices in their "WET" series for a long time. There are a number of others, with various characteristics.
The advantages of the WRT54G
L are more for general-purpose routing usage -- the needs for bridging are less, and once set up, there should not be a big difference between a WRT54GL and a WRT54G v5 when used as a simple wireless bridge.
The WRT54GL is supported by Tomato firmware though, which might be a bit simpler to set up as it's not as feature rich and potentially complex.
The instructions I gave previously for for setting up client bridge mode with DD-WRT are almost all you need to know after flashing. If you have any questions, ask. After that it's pretty much plug & play, and computers on both sides of the bridge can see each other.
