- Jun 23, 2004
- 5,464
- 8
- 81
Well, my wife called me out to the garage this morning saying that the garage door wouldn't open. I told her I'd be right out to fix it. (I assumed something was in the way of the sensors and that was her problem). NOPE!! Hit the button & nothing happened!
Finally figured out that the garage door opener had pushed right past the "closing trigger" and basically shut the garage door REEEEEEAL good! So I pulled the little "L" arm thingy off (pull a couple cotters & a couple pins & the "L" arm comes off). When I got that last pin out the pressure finally........"POW".......released.
Now I don't see anything obvious, so I unplug & plug the power cord back in & hit the button & it works. Goes all the way to the close trigger & stops. "OK", I say & hit the button again. NOTHIN'!!!! And it'll only go one time. If I unplug/replug the thing back in, it'll close every time, but it won't come back open. That's all I can do and to get it to do it I have to unplug/replug.
Obviously the motor works, but something's jacked up. Wife says "Just go buy a new one" but I know the PITA it's gonna be to spend a friggin' Saturday replacing the stupid power head. (Mind you, if I do I'll be smashing it into pieces with a sledgehammer & then sending the pieces to 'Genie' w/ my least respectable english attached in a note!)
