Any encryption in the Bin Laden intel that NSA can not break
gevorg
5,070
NSA has backdoor access to every password protection mechanism. No brute force needed.
Fox5
5,957
7
That'd be bad security practice, on account that someone else could find the backdoor. Traditionally, the US gov just kept exported crypto down to something that was easily crackable, but I think that restrictions been lifted with the advent of public key cryptography.
I think people are right, AES-256 will never be cracked by any amount of computing power we as a society will produce for the near future. That said, the amount of password guesses needed to just log into his computer is probably far less than the amount of key guesses needed to break the crypto.
SoulAssassin
6,135
dennilfloss
Past Lifer 1957-2014 In Memoriam
Oct 21, 1999
30,509
12
dennilfloss.blogspot.com
A security expert on Radio-Canada just said that most of the encryption codes used by terrorists are very simple. These folks simply don't expect to get caught.
ProfJohn
18,161
7
The CIA can't even decode the statue that has been sitting in front of their HQ for 20 years.... losers.
Nintendesert
7,761
Or he's like every other American with their data and didn't even bother to encrypt any of it.
SphinxnihpS
8,368
25
Is there anything we got out of the compound that is so deeply encrypted that even the NSA can't break it? Given time and the resources is there anything they can not crack?
You can not decode a "One Time Pad".
SphinxnihpS
8,368
25
The fourth figure, the one they can't figure out, is probably One Time Pad type encryption, and will never be decoded.
SphinxnihpS
8,368
25
If they repeat a section of the one time pad, then you can break it (for the overlapped portions)
It will give you a clue, but the messages on them are usually short, and "one time" so it might take several using the same pad with several different overlaps to really crack one.
A big part of cracking Enigma in WWII was because of overlaps (known repeated messages with the same code group), but that was far from the absolute encryption of a one time pad, and it took many repats for us to start understanding it, and the grunt work was done by the firt computers (reels).
