mobobuff
You pay for the upgrade (unless there's a deal going on) and pay a lease for the receiver they bring out to do the upgrade with. Best Buy is partnered with DirecTV, you could buy your receiver from them, and the technician will activate the access card after the installation. If you're a current DirecTV customer with a standard triple-sat dish, they'll also replace the dish with the 5-LNB model. Obviously you'll also pay a little more for your programming.
I used to work for DirecTV, if you have any other questions, feel free.
Right now I have Premier package that already includes the DVR service included. I pay $106 a month.
So the HD package is an extra $9.99. I guess if they have to replace the dish then so be it. Just hope they don't have to run extra cable line, i don't need more holes in the house.
They will need to run either 4 or 5 cables from the dish in to the multiswitch but they should be able to use the existing hole as long as your current dish is mounted in a place that will support the larger dish. I hear the new slimline dishes are not nearly as heavy as the one they gave me last year (+/- 45lbs) so that may not be as much of an issue as it used to be.
This is the dish that i have now and the location.
Pic 1
Pic 2
So I'm guessing you have two receivers right now, the DVR and a standard receiver probably in a bedroom. Unless you want the HD receiver to go in a new location, no new holes need to be drilled. The technician will just run 4 cables from the LNB to a 4x8 multiswitch, and use currently existing wire for everything after that. Yes the dish will be replaced with a 5-LNB model.
Actually I have three receivers. The living room receiver is the current Tivo DVR with two cable lines into that room. Then two single lines to two bedrooms.
I would like ad the HD DVR to the living room and move the current Tivo DVR to another room and hopefully get later on a regular HD receiver in the last room.
Oh okay, I see the fourth cable now. The technician just didn't follow code.
What you want will require more holes and at least one more run of cable from the groundblock (in this case, the multiswitch) to the receiver. If you request to replace one of your current standard receivers with your TiVo, the technician will probably try to get away without running a second line, and telling your TiVo to ignore the second tuner. Make sure he runs the second line. It'll be a pain in the ass for him, and he'll be getting paid chump change because upgrade work orders are a joke for technicians. Depending on who does the installations in your area, you might be charged additional labor for having receivers moved around and additional lines ran. $50-$75 usually. Also tell the technician that comes out to ground the new satellite dish. Your current one is not grounded, and it's hazardous for the receivers (and a violation of the NEC).
