Any difference between these two Tuniq coolers?
DaQuteness
200
34
86
It's perfecly identical, I have a Tuniq Tower 120, could have bought the other one but there is something about LED fans in combo with a cpu cooler that doesn't satisfy me. :laugh:
Rubycon
Madame President
Aug 10, 2005
17,768
485
Originally posted by: Jax Omen
Ok.... is the fan in the Tuniq Tower replaceable?
Yes it is however the supplied one is about as good as a match as you will find.
boomhower
7,228
19
I would argue that. It is not bad but quite loud on full tilt. The included fan controller does a nice job of quieting it down but if you need to run full on there are better choices, i.e. Scythe S-Flex
DaQuteness
200
34
86
If I switch the Tuniq for a Noctua NF-P12-1300 (the 9-blade design one) will it make any difference? My TT is in a push-pull cooler config, intake fan->Tuniq fan->exhaust fan. And one more thing... will i still be able to use the controller with it? I know something about it being a pulse width fan motor and not usable with normal fan controllers.
Rubycon
Madame President
Aug 10, 2005
17,768
485
I've tried at least a dozen different fans and always wind up using the supplied one as its balance of temperature maintenance vs. acoustics seems to be spot on.
