Originally posted by: Avalon
I'd say the difference would be minimal. I've used AS2, AS3, and AS5. Can't really say I saw a noticeable difference in temps between the models. The only thing that stood out to me was that AS5 was thicker than AS3.
Originally posted by: miketheidiot
Arctic silver 5 hardens up real hard and has caused lots of problems removing the HSF. Also its really thick and can be hard to apply.
True & I honestly can't say I noticed a temp difference between full spread and little pea size drop on the center of the CPU. I however did notice that with full spread, the CPU would stick hard to the heatsink while with the latter, it was much easier to seperate the two.Originally posted by: fixxxer0
Arctic Silver5 as far as I know does not get "spread" .... at least on A64's and the big processors.
I cant find the link again, but the AS5 application guide (from AS themselves) says to clamp the HS down with a small dab on the spot where the die is under the A64 heatspeader. It spreads out in a circle covering most of the square chip and they say its the best way. They also say to rotate the HS a little to the left and right to get out any bubbles that may form.
