Is there any difference in performance whether using 2 of the2gb (2x1gb) kit vs 1 of the 4gb (2x2gb) kit?
DDR2 800 (PC2 6400) Dual Channel Kit
the 2gb kit I'm looking at is here:
http://www.newegg.com/Product/...x?Item=N82E16820134488
For Intel 965 mobo, and assuming the 4gb kit has the same latency, etc as the 2gb kit.
Reason I'm asking, it seems like I read somewhere that using 2-2-gb kits instead of 1-4gb kit, it will not run dual channel mode??
Will be running XPsp2 to start, but thinking about getting 4gb now since I will more than likely move to Vista at end of year. (I know will only be able to use 3gb under XP even if have 4gb)
Reason I would get 2 of the 2gb kits instead one 4gb kit is that the 4gb kits seem like they're only available in the "non-value-ram" pricing level, so the 4gb kits cost a lot more.
thanks..
thanks..
