- Jan 16, 2001
- 31,528
- 3
- 76
First off, let me tell you what I want to build. I'm building a large cage for my biggest snake. No, not THAT snake
my Columbian Redtail. All seven feet+ and 15 pounds of her.
Basically, I'm building a huge, wooden box, with sliding glass doors (like a display case) in the front.
I want to build the cage out of 3/4" plywood, so I can stain and polyeurehtane (sp?) it to be water-resistant. The problem is getting the long edges to stay together.
I have experience building big subwoofer boxes, but I use MDF for that...much different than plywood.
I have a compressor and a nail gun that will shoot up to 2" nails, which I have a box of 2,000. I have copious amounts of wood glue. Wood screws will split the plywood, and pre-drilling plywood doesn't work either. At least not in my experiences.
I'd like to build this without any L-brackets, if possible, but I don't see how that will work.
Oh, the cage will be 84"w x 32"d x 32"h. This is a big cage. Glass will be hella expensive
Any help you can lend is greatly appreciated.
