any bottleneck issue with usb 3.0 pci adapter on old dell desktop system?
aigomorla
21,044
3,524
yes and no...
PCIe 1.0a, with a per-lane data rate of 250 MB/s and a transfer rate of 2.5 gigatransfers per second (GT/s).
vs USB3.0 which is 5gb/s ... so almost double...
HOWEVER...
the no is can u find a USB3.0 device which is that fast to begin with?
Because 250 MB/s and a transfer rate of 2.5 gigatransfers per second (GT/s) is in SSD territory... And not cheap SSD's either.. but your mid to high grade.
Also thats READ speed... you would need more then 2 in Raid to max it out on the Write territory.
So unless ur considering on Raid 0 2xSSD's on a USB3.0 enclosure.. id say no.
kreactor
709
so real world advertised 3.0 usb transfer speed are not really attainable ?
but this pci card would not be a "bad" purchase to move to usb 3.0 external storage vs paying about 20% less for usb2.0
thanks!
jkauff
583
13
You'll like USB 3.0 external storage. I have five 3TB WD My Book drives (Staples carries them, and they often have 20% off one item coupons) and their transfer speed is greater than my SATA3 to SATA3 transfers. If your MB mfg offers a "Turbo USB 3.0" utility (my Asus does), use it. It really does speed things up.
Cerb
17,484
33
86
No. USB 2.0 would never get 48MBps, either. That's marketing for you.
Still, there is no good reason to get a PCI-e USB 2.0 card. A USB 3.0 enclosure can get near-internal speeds for HDDs, and if the moon is aligned right, 400MB/s reads from an external SSD have been measured (not all chips or firmware implementations can do that, but you should pretty much always be able to get >100MBps from a USB 3.0 SSD). Also, USB 3.0 is not deathly slow for smaller transfers, like USB 2.0 was. In your case, with PCI-e 1.0, you should be capped somewhere around 220MBps.
aigomorla
21,044
3,524
thanks!
they are attainable..
however in your case seeing how old your system is... i dont think you will ever reach them.
Not unless u wanted to drop more money on a removable enclosure that costed more then your entire PC.
ie... 2x240gig Sandisk Extreme 2's = 700 dollars after tax + shipping.. would bottleneck your PCI-E lane on a USB3.0 card.
this is why i said yes and no..
yes you can bottleneck it... however no... as in it would cost you more then your PC to do so, and wouldnt be worth it.
So i also vote u buy a usb3.0 card... u will still get better latency and bandwith on it, even tho you bottleneck it.
