Picked up an Opteron 185 a week or so ago... Installed nicely, replacing Opteron 170. It running now at 2.6 GHz (stock speed), with 1.35 volts. Curiously, it was unstable at 1.30 volts, usually within 2 minutes. The stepping is supposedly pretty good,
being a CCB1E 0606VPMW - many of which can hit 3 GHz on decent air cooling.
In my case, the chip was mounted carefully under a Scythe Ninja with Nexus 120 fan (12V) attached to it. The thermal interface used was a small amount of AS Ceramique, applied carefully as per the Artic Silver website instructions. All this in an Antec P180. The chip is idling cooler than my 170 ever did by a few degrees... Specifically, I'm getting idle temps on the Opteron 185 of 37-38 degrees C. If I run dual prime the thing, it reaches 57 degrees C!! My Opteron 170 (running at 2.5 GHz with 1.425 Vcore) would never go over 51 deg C under identical circumstances.
I'd appreciate comments about what experience others have with this chip / stepping, or if anytone thinks I've failed to optimize some aspect of the setup. I've read some posts about taking the AMD heatspreader off, and using the core naked...and I'm not keen to do it - both out of risk to the chip, and because I've also read that the Ninja might not sit tight enough on a naked Opteron to be effective.
Thanks for the love...
A
A
