- Jan 5, 2002
- 164
- 0
- 76
As mentioned above, you can use it as a dedicated Physx card.
That's it. Don't expect to be able to do anything else with it. You can't SLI/Xfire AMD and Nvidia cards together, if that's what you were wondering.
I wouldn't bother. Trying to hack the drivers so Physx will work will give you marginal support at best and completely break every time you do a driver update. If you want Physx, you're much better off ditching AMD cards entirely.
I already have a spare GeForce 560, that's allI personally wouldn't want to deal with the headaches that would come along with this simply for PhysX. If it's really that much of a game changer for you sell the Radeon and Nvidia yourself entirely.
I personally don't find PhysX to be that impressive, but that opinion is based on videos and not personal experience so it may not be worth much.
I already have a spare GeForce 560, that's all![]()
Ah. Well, then I fully support your franken-setup. I'm all about experimental nonsense as long as it doesn't cost people hard-earned dough unnecessarily. And as long as they agree to feed us the juicy details later *wink wink*.
Turns out I can't. My PSU doesn't support two GPUs (not enough connectors and lack of power).
Sell the 560 and 7870, and get something better.
I think he was just looking to do an experiment. If anything he should just sell his 560 and get another 7870 (or vice versa). There's no single card out there better than those combos for under 800-1000 bucks.
A single 7970 GE has 80% the SPs and 50% more memory bandwidth, along with none of the usual CF weirdness issues.
I'd probably go with the 7970, personally.
And even if you think the 7870x2 is better than the 7970 (which it is, in terms of raw grunt, if not finesse) there's still the GTX 770/780 to consider, both of which come in well under $800.
If I think it's better? It IS better, and by a huge margin.
http://www.tweaktown.com/articles/4...reference_video_cards_in_crossfire/index.html
7870 x2 very nearly trades blows with a GTX Titan, and that's a $1k card. It basically crushes everything other than other higher-end CFX or Sli configurations. I'm not quite sure which aspect of performance "finesse" affects, but I think I'll leave it on the table for gains like those.
Crossfire "weirdness" is basically non-existent in modern games and the few games that do have issues are fixed with a frame limiter or adaptive vsync (and hopefully even that will be unnecessary after AMD's frame pace driver on the 31st). And a 7870 is $200 cheaper than the other options outside of 560 Sli.
Disagree about what? The numbers? Crossfire being fine in 98% of modern games? That's their choice I guess, but I'll stick with facts, numbers, and first-hand experience.
Crossfire "weirdness" is basically non-existent in modern games.
