Try rearranging your aquarium. I've that it helps when putting in new Cichlids because they all have to fight for new territory.
my 55L tank that I setup back in July...the cichlids have grown a bit since then...I switched back to freshwater after running a salt tank for 10 years...my LFS where I got my saltwater from closed down so water changes became even more of a PITA....
my old lion fish RIP
my salt tank before the redslime took over
Ah...a nasty green fish eater at the bottom of that tank...I loved serpent/brittle stars...but NOT the green fish eater.
I had two black/gray serpents for over 3 years...and they went to a friend when I took down the tank. This is the only one I was ever able to get a pic of:
The leg span on that one was over 18 inches. It was rare to see more than the tip of a tentacle or two waving in the current looking for a bit of food. I fed them with a skewer.
mine loved to come out at night...he would climb the front glass with arms fully extended...
Ever have any fish "mysteriously disappear?"
The green brittle stars are notorious fish hunters. VERY predatory.
AFAIK, they're the only ones that have that well-earned reputation.
Pistol shrimp, mantis...
One species in common use warrants a statutory warning. This is the Green Brittle Star of the genus Ophiarachna. This animal is a predatory fish eater, that does indeed do a spiffy janitorial job when small... but grows quickly, and under darkness of night can/does learn to eat aquarium fishes. This species has been documented to arch up in "sleeping caves" of captive fishes and drop down on unsuspecting meals. If you use this species, keep an eye on it, and a count on your piscine livestock.
I had a tank with a few hitchhiker brittle stars. I thought it was neat. Until they start reproducing like freaking crazy!
lol, me tooBy my calculations I understand roughly 20% of the words used in this thread.
Unless you plan on getting into reef keeping, you don't need to know them. They're mostly scientific names for the species abbreviated.
Sounds like a good idea, let the new fish fight it out and the strong survive, would help definitely my little 1-2" survive the move... :hmm: I may just have to get rid of him and get a bunch of little cichlids and let them sort it out, Id like to have atleast 30 in the tank (yes I know it might get overstocked a little).
They will continue to fight it out until either one takes over the whole tank or their is enough opposition to fight back .
This is the cichlid in my main tank.
He is about 3 years old and completely rules the tank, nothing challenges him , at least not for long. He has his fins up trying to show he is the biggest fish in the tank to the little guy on the right who entered his side of the tank. They have one of the most interesting challenge methods. They will circle each other in the tank head to tail in a small circle then stop and meet face to face. Slowly they will move towards and backwards to each other up and down the tank not breaking their eye contact, then suddenly one will use his mouth to cover the others mouth and hold on shaking back and forth till one gives and breaks free. The loser will find a corner of the tank and hide near the surface with its head near the water line. It will stay there for days until it thinks it can challenge again. When they get big like these it can scare you at first when they start fighting, they throw water on the floor quite often or you will hear a loud thud where one has run into the glass running from the other. Most of the time mine are pleasant but occasionally they still get into fights.
The one that is a large male even knows that I disapprove of the fighting. If I am laying on the couch and they are fighting I can move my foot to the floor and the male will swim as fast as he can to his cave and hide. I can wave my arms and nothing, but let my foot contact the floor and he has figured I am about to put a stop to it.
I've always been interested in aquariums but havn't settled down somewhere that would allow me to start one properly. What would a typical, lower budget salt water setup cost initially and monthly?
IMO, "saltwater" and "Low budget" don't belong in the same sentence.
Yes, you can go "low tech" and not have the intense lighting that are needed by corals and other animals that depend on photosynthesis...just focus on fish, but once you get the bug..."low budget" goes out the window pretty quickly.
I definitely agree that the larger the tank, the easier it is...more water volume means more room for errors. Minor temperature differences are slower to affect the tank, more volume means it takes longer for pollutants to build up, etc...BUT, the larger the tank, the more expensive it get to maintain, to light, heat, and filter properly.
I haven't had to buy salt mix in several years, but it USED to be available (on sale) for about $10/50 gallons. (Instant Ocean brand...not the best on the market, but better than most, and it works very well)
I used a good quality RO/DI filtration system to make my own purified water for use in mixing saltwater. It's better to start with good clean water than to have to fight all the various pollutants that are allowed in "drinking water" from the tap.
You also have to add clean, fresh water to the tank as water evaporates. You don't add saltwater as "make up water" because doing so increases the salinity beyond what's healthy for the animals in the tank.
I understand that "low budget" doesn't fit well, which is why I said "lower budget".
If someone didn't want to go all out the very first time with large amounts of coral, fish, etc, but wanted to start small (large tank, small population) and expand, what would the starting costs be for equipment that isn't budget low but not crazy expensive?
