rsutoratosu
Dont want to spend a ton but like to have something that'll last a while.. any recommendations ? i say 250 tops ?
It really depends on your intended usage. BTW, there are HOT and COLD pressure washers too, but are more expensive (usually for commercial use).
http://www.lowes.com/cd_pressure+wa...il-_-SellingTool|Pressure_Washer_Buying_Guide
Volume of water is just as important as PSI for cleaning, and can make the cleaning go a heck of a lot faster. A lot of people get hung up on the PSI; sort of like "this camera has more megapixels." If you're planning on using it once a week, personally, I'd go with a better unit than one of those electric ones, but to each their own. Or, to put it another way, power = the rate at which work is done. The tinier the pressure washer, likely, the less power. Do not be fooled by "our pressure washer saves uses less water because it only uses 0.8 gallons per minute." Because it's going to take 5 times as long to wash with one as it does with a 3gal/min washer.
i posted a similar thread in the garage. i think i'm just going to rent one or hire someone when i need my house cleaned. to get anything decent will cost upwards of $8-900 it seems. all of the cheaper stuff seem to crap out after a season or two. I was pretty close to getting that $300 unit at costco that has a honda engine, simspon brand i think, but all of the other parts crap out quickly and its tough to get replacements for them.
