any 64 bit lunix ready for prime time?
Discussion in '*nix Software' started by OBLAMA2009, Nov 3, 2012.
  1. Cerb
    Cerb Elite Member
    Aug 26, 2000
    17,409
    It should go up to nearly all of your RAM, then sit there, barring running and closing memory-hogging applications. While it defaults to some automatic value (sqrt(lowmem_kbytes*16)?), Linux keeps a good few MBs free--really free--and does its best to keep all the rest of it in use.
    I was unable to even change the GTK and KDE themes without programs crashing. Nepomuk still hasn't fixed its 100% CPU use bug, either, and still likes to crash (I have the same issue on Arch--it's not Ubuntu causing the problem, but software known to have such problems should not be included yet). PCManFM likes to unceremoniously close when transferring files over the network, too. It's not something new: 9.04 was the last just-released non-LTS Ubuntu I found good enough right after release. They'll get it fixed up, but that can mean GBs/week of updates, and some in-use annoyances, for now.
    12.04 LTS, OTOH, is rock solid. All it may have issues with is a slightly old kernel (a problem for virtualization on IB, FI), but anyone likely to encounter such problems aught to be capable of acquiring or building a kernel. Pretty much everything but the kernel itself gets good backports, and there are PPAs for newer kernels.
    #26 Cerb, Nov 9, 2012
  2. Leros
    Leros Lifer
    Jul 11, 2004
    21,881
    I use Ubuntu 10.04 64-bit and 12.04 64-bit for my work and home computers. I've had absolutely no problems with either.
  3. Aggdaddy
    Aggdaddy Junior Member
    Dec 28, 2011
    9
    I've been using Fedora 64bit on core 2 duo and AMD phenom quad core for a month. Rock solid performance. Pretty green on linux. Haven't played any games on it outside of browser games. But, no crashes or slow performance whatsoever.
    I use a windows 7 vm for work and it never goes down or give me issues.
