Antivirus with low memory usage
Sureshot324
3,370
Which antivirus would you recommend if low resource usage was the most important thing, but of course a good detection rate is important as well? Both noton antivirus 2004 and panda titanium seem to use 30-40mb of ram for me, and i'd like to find one that uses a lot less.
Schadenfroh
38,416
4
Grisoft's Free version of AVG. uses less than 5mb of memory, here is proof. i have used both and avg seems to update more often than symantec.
Sureshot324
3,370
According to all antivirus roundups i've found on the net, AVG has a poor detection rate compared to most other well known antivirus programs. Unfortunatly the reviews i've found don't really comment on memory usage.
John
Moderator Emeritus<br>Elite Member
NAV 2003 uses roughly 15MB (3 processes) and is friendlier than NAV 2004.
crazycarl
548
Originally posted by: Hardcore
Panda. Not only does it take up less than 2 megs in memory, it's virus list is updated multiple times a day (at least 4 that i've counted), and has one of the best detection rate out there. Not only that, but it's FREE!
Go to this site http://us.pandasoftware.com/products/platinum7/ to download the trial...
then go here http://www.pandasecurity.com/survey/ to apply for a free registration! You can thank me later.
my panda takes up 35 megs of ram on xp........ how did you get it it down to 2 megs?
4 processes: Avengine.exe, PAVFIRES.EXE, Pavsrv51.exe, APVXDWIN.EXE which I believe are all from panda.
ZimZum
1,281
Originally posted by: Raincity
NOD32 and Dr. Web have good detection rate and is low on the resources.
Yep, Nod32 uses the fewest resources of any realtime antivirus. I switched from Norton 2004 to Nod32 and everything from my boot time to Video encoding is noticeable faster.
Zepper
18,998
Trendmicro.com PC-Cillin (available for free with many items like mobos, VCom's SystemSuite 5, etc.) uses little resources also the AV from Computer Associates (eTrust EZArmor) had a 1 yr free trial availble via the M$ web site.
.bh.
