Antialiasing causes keyboard problems in Need for Speed III
Jeff7
41,596
19
Makes no sense to me either. But when I enable antialiasing and run NFSIII, the keys seem to stick sometimes, for up to 5 seconds at a time, during which time, the game keeps going, but the keys do nothing.
DaveSimmons
40,730
670
Try dropping down one screen res (e.g. 1024x768 -> 800x600) and see whether that fixes it. If so, it's probably time to upgrade :)
Jeff7
41,596
19
It's at 800x600 already; that's the max that the game will allow. Only in 16 bit color.
I've already run Giants at 1280x1024 in 32 bit color with 4xFSAA enabled. It was only about 6 fps, but the keyboard keys didn't "stick" or freeze the way they do in NFS. NFSIII with the 4xFSAA enabled is still very liquidy smooth though, disregarding the keyboard weirdness.
Gnollguy
26
What OS, and video card are you running? Is this single player of multiplayer? Do you have a game pad or joystick you can use to see if you have the same problem with that?
Jeff7
41,596
19
Win98SE
DirectX 8.1
Geforce2 Ti with 28.32 (I think, not at the comp right now - latest official Dets)
Single player mode
Using only the keyboard - joystick isn't plugged in, and the mouse steering is disabled.
Basically, the ONLY setting that is different here is the antialiasing that makes the keyboard controls go funny.
