- Jun 30, 2004
- 16,821
- 2,143
- 126
Until September, 2018, my Trooper was just "my old ride", and I let my veteran mechanic call the shots about repair and maintenance, while I ignored typical owner fetishes, like cleaning the 5-year-old guano plops off the hood. Maybe once in a while I'd look at the EC in the radiator, check the oil or transmission Dexron.
Then, we were recycling old electronic garbage to the county hazardous waste facility. I coordinated with a friend across town, who had about six old tube-type TV sets, one of which was a big 32-incher and weighed a ton. We put it in the back of the Trooper, and I gave no thought to tying it down or padding the space between the TEE-VEE and my windows. We went over the gutter at the end of my friend's driveway, when we heard a "Crunch" sound. The TV had pitched backward to shatter my rear window.
The following morning, I noticed that the LED indicator at the Anti-Theft On-Off switch was flashing wildly. When it was behaving normally, it would flash on when you opened the car door, and then go back to sleep. My mechanic told me not to bother: people might see the flashing light and assume the VSS was armed. But I looked into the matter by checking the diagnostic charts in my Factory Workshop Manual. The symptom links to either a damaged connection in the wiring harness, or a "tripped" door/window sensor.
I just acquired an OBD I/II code scanner:
Actron CP9670 OBD Code Scanner
I'm just beginning to "study up" on this device, and its published guide, bundled in the package, doesn't get rave reviews from DIY users. It doesn't look all that great to me either, but the manufacturer has an online PDF that is much more thorough.
Like other OBD scanners, this unit has an ability to reset codes stored in the ECU or ECM. Or so the literature seems to indicate -- and you might then begin to wonder exactly what they mean by the word "reset".
But it dawned on me that -- possibly -- I don't need a mechanic to take apart my Trooper's back door and fiddle with anything there. It may be possible, I thought, to reset the VSS with the code scanner.
Am I dreaming? Imagining? Speculating? Or is this true? Could I . . . fix my VSS' behavior . . . with my Actron Code Scanner?
