My wireless network setup consists of a Dlink 614+ wireless router and a Dell Truemobile 1150 flashed to Orinoco gold firmware. I just purchased this card expecting better range than my Dlink 650+. The range is slightly better, but not much. I am looking at purchasing a cheap antenna for my router. I have a few questions before I do. First, I am in a dorm room with cinder block walls. I would like to be able to get to a friends room only 2 rooms away. It is only about 40 feet from my router, but there are 3 cinder block walls and 2 regular walls in the way. Currently, I can pick up my router and connect to it in my friends room, but the connection drops constantly. I am guessing I don't need a great antenna to pick up the signal just a bit. I was looking at this antenna. Do you think it would fit my needs? Can I purchase only one or do I need to replace both antennas on my router? Would I need any other adaptors to make this fit my router? Is there a better antenna for not a whole lot more? Maybe $40 max.
I was also looking at an antenna for my laptop for occasional use when I want to go just a bit further. Woud this this work?
Sorry for all the questions. I am new to the wifi and antenna stuff.
Thanks for the help,
Brian
Brian
