Antec Veris Fusion v2 Problem
rimmi2002
I have the Antec Veris Fusion v2 case. Installed it on a ASUS M4A78-EM mobo. For VFD display the instructions are to "Connect the 3-pin power cable from the display to the 3-pin connector on the 24-pin ATX main power connector of the power supply." I did that, but the problem is that when I attach the two, my mobo status light will starting blinking green and the system does not startup. When I disconnect the connection the between the two mobo status light become a solid green and the system powers up and works fine. Any idea where the problem is here? I really don't care about the LCD display that much...but I am more worried it this means a defective PSU or misgrounded VFD display? Like I said I don't care much about the display, but I would like the system to power through a MCE remote. will it do that with the 3 pin connector not connected? Any help would be really apprecaited. thanks.
