Smokin Gunn
Product Link
True550 is a 550 Watt 6-output, dual fan-cooled ATX (Baby AT or PS/2 Size) power supply designed for personal computer or industrial applications.
Its ATX 12V compliance allows its use with the latest Pentium 4 processors while its backward compatibility ensures its usability with any system
TruePower
The One Component You Never Think of May Be The Most Important.
Introducing TruePower from Antec: the all new line of PC power supplies from the company that has led the way in power supply design and quality since 1986. These power supplies feature dedicated output circuitry for each voltage so that each output delivers maximum power whenever you need it. To make sure these voltages stay accurate, TruePower also includes voltage feedback circuitry to improve system stability.
Antec Low Noise Technology
Antec Low Noise Technology is a new approach that achieves optimum balance between noise reduction and necessary cooling. To this end power supply fans run at the lowest speed appropriate to load and conditions, under an advanced temperature response system that outperforms previous solutions. Further dedicated Fan Only power connectors allow TruePower power supplies to control the speed of case fans, too.
Important Note: The TruePower Fan Only connectors are designed to power standard fans only. Attaching thermally-controlled fans to these connectors will likely result in unpredictable and undesired behavior. Thermally-controlled fans should only be connected to the standard 4-pin Peripheral Power Connectors.
TruePower
