My old temp, with a OEM PSU in my Aopen case:
46 idle, 55 load
new temps:
52 idle, 57 load
I mean I know this PSU is supposed to run quieter, and it does I think... but I figured having dual fans would help suck the air off the CPU a bit. I admit I don't have the best cooling setup, 57 is probably expected, but even so how did it raise even if I added an exhaust fan (the one in the psu)? I don't recommend using this PSU as means to cool off your system if you're overclocking, you'll definitely need another exhaust fan in the back.
			46 idle, 55 load
new temps:
52 idle, 57 load
