Originally posted by: Ilmater
I was looking extensively into whether or not my power supply was giving my system enough power when I came to
this site. It goes over the power consumption (in amps) of many popular devices. I added up everything and came up with 6.5A on the 3.3V rail, 15.7A on the 5V rail, and 25.5A on the 12V rail. The load on the 12V rail comes from 4 hard drives (1 SCSI, 3 IDE) that I found exact specs for, 9 case fans, a CDRW and DVD-ROM drive that I found exact specs for, a small (0.3A) draw from the motherboard according to FiringSquad's recommendations, and 10A from my CPU. Now I fully understand that the 10A from an overclocked 1700+ is more than neccessary, but as I'm upping the clock and voltage (the two things that have a direct impact on amp draw), I wanted to be absolutely sure I had enough power to be fully stable. I didn't want there to be any question whether or not my power supply was my bottleneck.
I currently have an
Enermax EG465AX-VE(W) FCA powersupply. The output capacities are 38, 44, and 33A on the 3.3, 5, and 12V rails, respectively. This was easily enough to take care of my needs, even with the 3.3V and 5V rails coming from the same source (and thus having 220W of available power, total). I had been looking at Antec as an alternative because of their obvious reputation for having the best power supplies. However, upon looking at their specs, I found that the max load on Antec's top-of-the-line 550W TruePower PSU was only 24A on the 12V rail. Now, admittedly, I have more hard drives than most, but I still think this unacceptable from a 530W PSU.
With all the hooplah surrounding Antec's TruePower series, I really expected more. Am I missing something? Here are the links to the specs on
Enermax's EG465AX-VE(W) FCA 435W model and
Antec's 530W TruePower550 model.
