Hello, If someone could please help me with a power supply issue I'd appreciate it. I have an Antec Truepower 380s (www.silentpcreview.com/article61-page1.html) from my old Sonata case that recently stopped working reliably. My HTPC will no longer boot consistently with the Antec PS installed. The first boot when I turn on the switch at the back of the PSU always works just fine. Subsequent booting is the problem. I often have to press the power button dozens of times to get the PC to boot, if it will boot at all. I know it's the power supply, because replacing it with a spare PSU allows the PC to boot normally and reliably. My System: Antec Sonata Antec Truepower 380s Abit KN8-SLI motherboard AMD Athlon 64 x2 4200+ 4GB DDR Radeon 4550 512MB WD 1TB Green Drive. I've used two inexpensive PSU testers and a multimeter to test it as well as I can but those tests have given me some results I don't quite know what to make of. Multimeter Readings pin 1 3.3v = 3.36 pin 2 3.3v = 3.36 pin 3 GND = 0.00 pin 4 5v = 5.09 pin 5 GND = 0.00 pin 6 5v = 5.09 pin 7 GND = 0.01 Pin 8 PG = .06** pin 9 5Vsb = 5.19 pin 10 12v = 12.09 pin 11 3.3v = 3.36 pin 12 -12v = -11.95 pin 13 GND = 0.00 pin 14 green pin 15 GND = 0.00 pin 16 GND = 0.00 pin 17 GND = 0.00 pin 18 -5v = 5.0 pin 19 5v = 5.09 pin 20 5v = 5.09 ** PG reading is strange. Both PSU testers fail on it until I plug the extra 12v P4 connector in, then they quit complaining. Measuring PG. 1. Table top with green wire shorted to ground reads .06v 2. Tester 1 with 12v P4 connector plugged in reads 3.6v 3. Tester 2 with 12v P4 connector plugged in reads 5.06v So yeah, I don't get what's going on here. Something is obviously wrong with the PG signal, but why does it sometimes work, and other times not work? At this point I'm perplexed. I'd like to keep using the Antec 380s because it's still a pretty quiet unit and I'm using this as my HTPC in my living room. Any help you could give me is appreciated, Thank You,
