- Dec 14, 2000
- 1,034
- 2
- 81
I have 2 antec sx830's and am looking for 2 fan mounts (the purple plastic things) but I'm noticing it appears there are 2 different types.
In both cases I got both rear exaust mounts and fans (no problem there) but in one of the cases, I got the 2 lowest position mounts, and in the other I got the lowest position mount and the highest position mount that appears to only fit in the drive cage.
I am looking for one of each (normal low position one and highest position drive cage one)
Does anyone know where I might be able to find these? I checked with the place I bought them and they said they had no idea.
Thanks
Thanks
