Antec Sonata TruePower 380 fan problem...
FingerDemon
19
I just installed an A7N8X Deluxe in an Antec Sonata case with the 380 TruePower Power Supply. Everything works pretty well considering I had never built a machine before. But ASUS Probe reads that the Power Supply fan is not working. I downloaded the latest ASUS Probe, but still no go. I can't figure out how to set this up so AsusProbe reads things correctly. Is the TruePower spinning at too low a speed? I have it set to a low threshold of 600 RPM (the lowest it can go). But I think the fan spins way faster than that, right? Anyway, if anyone can shed any light on this, I'd appreciate it.
I guess it is possible the connector on the motherboard I am using is bad, but I don't know how to check that either.
Thanks,
FingerDemon
BG4533
1,892
Many boards can only read speeds above 2000RPM. My 430 isnt detected on my boards. To check the connector simply put a fast fan on there with a RPM sensor.
Brian
ronnn
3,918
Is the antec sonota quiet? Also how does it cool? I am waiting for mine to arrive.
Syborg1211
3,297
26
This might seem like a stupid question, but do you have the 3-pin motherboard sensor that comes out of the power supply hooked up to your motherboard? Also, do you have the sensor hooked into the right 3-pin on the motherboard?
