I have 4 HDDs in my machine in an Antec Sonata and I am using an enermax 94cfm 120mm exhaust fan only. I am including a picture of my computer's "guts" where I did have a fan next to the HDD rack up until 3 days ago. After I installed my 7800GTX, I found that the card is so long the PCIe power connector won't fit in with the fan in place. It had to come out. So......
My question is, at idle my HDDs run between 38c and 41c. Is this considered an "unsafe" operating temp?
I plan on adding a blowhole over the CPU/GPU on the side panel using another enermax 94cfm 120mm fan which should move a lot of air into the case.
Do you think adding a blowhole to the side of the case closest to, but not on top of the HDDs drawing air in would:
A) Mess up the airflow design of this case
B) Help in cooling the HDD even though the fan wouldn't be directly on the HDDs?
Or should I just get a bigger case with an intake fan near the HDDs so air can flow over the HDDs?
Opinions/suggestions are greatly appreciated.
Pic:
http://images.dr3vil.com/uploads/PICT0087.JPG
Pic:
