Antec Sonata Case Front USB
gokuhama
59
i was just wondering if anyone knew whether the front usb ports on the Antec Sonata Case was compatible with usb 2.0.
gokuhama
59
sorry i just want to clarify myself. i know it can be used with high-speed devices, but are they actually high speed ports or merely usb 1.1 ports?
mikecel79
2,858
Yes they are USB 2.0 ports meaing if you put a USB 2.0 device it will work at the rated 480Mbps.
Baked
36,052
17
They are USB 2.0 ports if you connect them to USB 2.0 headers on the mobo, USB 1.1 ports if you connect to USB 1.1 headers.
gokuhama
59
oh ic. thanks i thought that the controller was on the case. makes sense if it uses the mobo controller
Zepper
18,998
Sonata should have USB 2 capable wiring to the front panel, but there have been lots of threads here about varius Antec models (not sure which - too many to keep track of) not being able to run at USB 2 speeds. IAC, Antec will send you a new front cable assembly if yours doesn't work.
.bh.
:moon:
WobbleWobble
4,867
Not all are USB 2.0. They're supposed to and even advertised to be.
The PCB even said USB 2.0 even though it didn't work. I had a Sonata and tried a USB 2.0 drive in the front ports and it didn't even detect it. Found out there was an issue with the Sonata and other Antec cases and called Antec up. They sent me new USB ports (free) and it works fine now.
