Might be the better deal if shipping is too high for you. Plus you can use some McDonalds BestBuy bucks (not sure how that works in regards to limits -- I only have $2 and I'm not sure I can eat more McDs).
I brought the SLK2650-BQE about 6 months ago and it looks like the same case as the 1650 except it has features that are supposed to make it quieter like rubber mounts where you attach the hard drives and some other things. The only thing I don't like about the 2650-BQE is that the front USB ports seem cheap/fragile. They also stopped working on mine but it might be a BIOS issue or the internal cord may have gotten unplugged (I'm at work else I'd check right now). If it wasn't for the cheapo feeling on the front USB, the slight annoyance of having a front door that opens, and the lack of audio ports on the front of the case I'd pick another one up right away. As it is, for the price with a good 350w power supply, I'd still consider picking another one up.
