as title states is there a case you would recommend as a replacement for this case.
like price and 2x120mm fans
would like front usb and audio with no door
also suggest good power supply for a gamer with a 6800gt and amd athlon 64 that is a reasonable price. I like the antec and seasonics but they are twice as much as the case and about as much as the CPU. Any lower cost alternatives you might recommend?
