ANTEC Replacement Side Panels
EKKC
5,895
My friend got this used, but pretty good condition, Antec case (along with the original PSU, mobo and a P4 chip) from his workplace that has been phased out. but it has no side panel for the case.
I tried searching on antec.com but can't seem to find any replacement panels in their spare parts section.
The case is Antec Solution Series SLK3700AMB
http://www.antec.com/us/produc...ails.php?ProdID=93700#
thanks.
DaveSimmons
40,730
670
Nice case, good luck.
I've used mine for a music server and then my last 2 gaming PCs. The only thing the case is missing is a side panel duct for bringing cooler air to the CPU.
EKKC
5,895
maybe then leaving it wide open would be a fix to that problem for me :laugh:
thanks for the help guys
ViRGE
Elite Member, Moderator Emeritus
167
Try contacting Antec directly before you give up. I was able to get a P160 3.5" cover out of them a couple of years ago, even though they weren't listed.
BassBomb
8,390
0roo0roo
64,795
84
its a cheap case, its probably not worth the shipping for side panels.
would rapidly approach the cost of a new case i bet. hell a p180 is on sale with rebate for 50 now at frys/outpost.
for a solutions series... buy a piece of plexi and hot glue it place or something. it doesn't matter:p
