This is not to debate the merits of quality Vs generic power supplies.
Of course quality should be much better, since you pay a premium.
But it may come as a surprise to some that quality parts fail too.
Just as often? Of course not. But, how often?
In poll, if you can choose multiple answers, try to answer highest choice. I know it may skew results to Antec, but I think enough like Antec to avoid wrong end results.
Having always used the cheap power supplies when building low cost gaming systems, (case with power supply for under $40), and never any failures in over 3 years and dozens of systems, updated my personal system to try out the Aria with it's 300w Antec supply.
In short, wasn't happy with temps and case, so went back to old Athenatech case, and moved the Aria to be used as an extra lan gaming rig. Very minimal parts used, such as onboard GF4 MX440 video, sound, lan. No AGP/PCI cards used. No overclocking Sempron 2400+. About as basic as you can get.
Died after about 6 months and 140 hours of light use. I was floored by this, because all posts say how great Antec is. More research on the net showed that they did have issues in the past. Is this isolated?
BTW, replacement power supply is on it's way back to me, which means down time will only be about 3 weeks. :frown:
Antec case used proprietary power supply, so I couldn't even use generic as a temporary solution.
