Antec PlusView - Fan Placement
AHoward
I am having a computer built with an Athlon 64 3200+ (2.2GHz, 512K cache) cooled by a Thermaktake "Silent Boost" and eVGA Geforce 6800 GT. Do you think an Antec PlusView case with stock cooling would provide sufficent airflow? The case comes with 2 80mm fans in the back to blow out warm air, with room for 3 more (2 in front, one on the side panel). I do have an extra Antec 80mm and was wondering which spot I should put in in, and if I should set it for blowing air in or out of the case. Thanks.
I'm using the same case. I would think it is enough, but the side intake might be useful if you have hot PCI/AGP cards like the 6800GT. The front intakes dont' really do much, but one of them does cool your HDDs if you have them in that particular cage.
