Has anyone successfully hooked up the front firewire on the antec plus660amg to a P4PE motherboard? The antec case only has one pin for the VP and one pin for the GRND header, but the motherboard has two pins for both VP and GRND. Will the headers on the motherboard only work with the card/wire connections came with the motherboard? Also does it matter which direction the wires go on to the header? I put pastic ends facing out so their labels (TPA+, TPA-, etc.) could be read. Does that matter?
Should this question be in the motherboard forum?
Thanks for the help.
